Ir para o conteúdo principal
HTC Touch Front Buttons Replacement
O que você precisa
  1. HTC Touch Front Buttons Replacement, Front Buttons: passo 1, imagem 1 %32
    • Using your finger, remove the back panel by sliding it up.
  2. HTC Touch Front Buttons Replacement: passo 2, imagem 1 %32
    • Remove the battery.
  3. HTC Touch Front Buttons Replacement: passo 3, imagem 1 %32
    • Remove the four screws in the corners of the phone using the T5 Torx screwdriver.
  4. HTC Touch Front Buttons Replacement: passo 4, imagem 1 %32 HTC Touch Front Buttons Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to remove the front panel from the phone.
    • Unplug the front button cable from the inside of the phone.
  5. HTC Touch Front Buttons Replacement: passo 5, imagem 1 %32
    • Remove the two screws from the back of the front panel using the Phillips #00 screwdriver.
  6. HTC Touch Front Buttons Replacement: passo 6, imagem 1 %32
    • Remove the small circuit board by gently pushing on the center button on the front of the phone.
  7. HTC Touch Front Buttons Replacement: passo 7, imagem 1 %32
    • Remove the buttons by pushing on them from the front side of the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Brooks
Membro desde: 04/13/11
104 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-12, Regan Spring 2011 Membro de Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Membros
Autoria de 10 guias
1Comentário do guia
I need the keypad flex cable. Where to buy. Please guide smahapatra2012@gmail.com
subhas mahapatra - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 59
Ao todo: 3,207
