Ir para o conteúdo principal
HTC Surround SD Card Replacement
O que você precisa
  1. HTC Surround SD Card Replacement, Back Case: passo 1, imagem 1 %32 HTC Surround SD Card Replacement, Back Case: passo 1, imagem 2 %32
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround SD Card Replacement: passo 2, imagem 1 %32 HTC Surround SD Card Replacement: passo 2, imagem 2 %32 HTC Surround SD Card Replacement: passo 2, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround SD Card Replacement: passo 3, imagem 1 %32
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround SD Card Replacement, SD Card: passo 4, imagem 1 %32 HTC Surround SD Card Replacement, SD Card: passo 4, imagem 2 %32 HTC Surround SD Card Replacement, SD Card: passo 4, imagem 3 %32
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround SD Card Replacement: passo 5, imagem 1 %32 HTC Surround SD Card Replacement: passo 5, imagem 2 %32
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 250
