Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
By taking off the cover, and unscrewing the back of the phone we will reach the motherboard to replace.
The motherboard controls the software of the phone and is an essential piece to any logic process.
O que você precisa
Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
To remove the back casing inside the phone, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
Next, unscrew the top screw using a small, Philips screwdriver. You will now be able to pull the motherboard back.
Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
Uma outra pessoa concluiu este guia.
