Ir para o conteúdo principal
HTC SMT 6175 Keyboard Replacement
O que você precisa
  1. HTC SMT 6175 Keyboard Replacement, Back Case: passo 1, imagem 1 %32
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Keyboard Replacement: passo 2, imagem 1 %32 HTC SMT 6175 Keyboard Replacement: passo 2, imagem 2 %32
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Keyboard Replacement, Battery: passo 3, imagem 1 %32 HTC SMT 6175 Keyboard Replacement, Battery: passo 3, imagem 2 %32
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 HTC SMT 6175 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • To remove the back casing inside the phone, remove the six screws around the perimeter.
  5. HTC SMT 6175 Keyboard Replacement: passo 5, imagem 1 %32 HTC SMT 6175 Keyboard Replacement: passo 5, imagem 2 %32
    • Carefully pull off the back casing.
    • This step may be difficult. Start pulling the back out from the front shell. As it starts to lift up, move the phone side-to-side until the whole back is free.
  6. HTC SMT 6175 Keyboard Replacement: passo 6, imagem 1 %32 HTC SMT 6175 Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the top screw.
    • Be CAREFUL, because the LCD screen is attached to the front side of the motherboard by a flexible ribbon cable.
  7. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: passo 7, imagem 1 %32 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: passo 7, imagem 2 %32 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: passo 7, imagem 3 %32
    • Pull the plastic keyboard away from the front case.
  8. HTC SMT 6175 Keyboard Replacement, Navigation Keys: passo 8, imagem 1 %32 HTC SMT 6175 Keyboard Replacement, Navigation Keys: passo 8, imagem 2 %32 HTC SMT 6175 Keyboard Replacement, Navigation Keys: passo 8, imagem 3 %32
    • To remove the navigation keys on the front of the phone, remove the four screws securing the navigation keys using a Phillips screwdriver.
    • Remove the navigation keys from the front of the phone.
    • They should pop out as a unit.
Conclusão
Luke Plewa
Membro desde: 04/22/11
116 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 25-29, Garner Spring 2011 Membro de Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,665
