Ir para o conteúdo principal
HTC Rhyme charging port Replacement
O que você precisa
  1. HTC Rhyme charging port Replacement, Charging Port: passo 1, imagem 1 %32 HTC Rhyme charging port Replacement, Charging Port: passo 1, imagem 2 %32
    • Image of the front and back of the HTC Rhyme.
  2. HTC Rhyme charging port Replacement: passo 2, imagem 1 %32 HTC Rhyme charging port Replacement: passo 2, imagem 2 %32 HTC Rhyme charging port Replacement: passo 2, imagem 3 %32
    • Remove the back cover by pulling down on the lower half.
  3. HTC Rhyme charging port Replacement: passo 3, imagem 1 %32 HTC Rhyme charging port Replacement: passo 3, imagem 2 %32 HTC Rhyme charging port Replacement: passo 3, imagem 3 %32
    • Use a T5 to remove the five highlighted screws in the image.
  4. HTC Rhyme charging port Replacement: passo 4, imagem 1 %32 HTC Rhyme charging port Replacement: passo 4, imagem 2 %32
    • Once the screws are removed, slide the back cover off of the phone.
  5. HTC Rhyme charging port Replacement: passo 5, imagem 1 %32 HTC Rhyme charging port Replacement: passo 5, imagem 2 %32 HTC Rhyme charging port Replacement: passo 5, imagem 3 %32
    • Remove the two screws highlighted in the image with a Phillips screwdriver.
  6. HTC Rhyme charging port Replacement: passo 6, imagem 1 %32 HTC Rhyme charging port Replacement: passo 6, imagem 2 %32
    • Push off the small silver piece resting above the charging port.
  7. HTC Rhyme charging port Replacement: passo 7, imagem 1 %32 HTC Rhyme charging port Replacement: passo 7, imagem 2 %32 HTC Rhyme charging port Replacement: passo 7, imagem 3 %32
    • Disconnect the black cable on the upper right side of the motherboard.
  8. HTC Rhyme charging port Replacement: passo 8, imagem 1 %32 HTC Rhyme charging port Replacement: passo 8, imagem 2 %32 HTC Rhyme charging port Replacement: passo 8, imagem 3 %32
    • Disconnect the green cables in the upper center section of the motherboard.
  9. HTC Rhyme charging port Replacement: passo 9, imagem 1 %32 HTC Rhyme charging port Replacement: passo 9, imagem 2 %32 HTC Rhyme charging port Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the yellow cable by gently pulling on it with tweezers.
    • When assembling, use your fingers to reconnect the wire.
  10. HTC Rhyme charging port Replacement: passo 10, imagem 1 %32 HTC Rhyme charging port Replacement: passo 10, imagem 2 %32 HTC Rhyme charging port Replacement: passo 10, imagem 3 %32
    • Disconnect the white cord on the lower left side of the motherboard.
  11. HTC Rhyme charging port Replacement: passo 11, imagem 1 %32 HTC Rhyme charging port Replacement: passo 11, imagem 2 %32 HTC Rhyme charging port Replacement: passo 11, imagem 3 %32
    • Gently remove the motherboard with your hand.
  12. HTC Rhyme charging port Replacement: passo 12, imagem 1 %32 HTC Rhyme charging port Replacement: passo 12, imagem 2 %32 HTC Rhyme charging port Replacement: passo 12, imagem 3 %32
    • Desolder and remove the charging port on the motherboard.
    • Solder a new charging port onto the pads where the previous charging port had been.
  13. HTC Rhyme charging port Replacement: passo 13, imagem 1 %32 HTC Rhyme charging port Replacement: passo 13, imagem 2 %32 HTC Rhyme charging port Replacement: passo 13, imagem 3 %32
    • Follow steps 11 through 1, to put the phone back together.
Conclusão
Rebecca Chapman
Membro desde: 06/01/16
104 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 300
