Ir para o conteúdo principal
HTC Rhyme Speaker Replacement
O que você precisa
  1. HTC Rhyme Speaker Replacement, Speaker: passo 1, imagem 1 %32 HTC Rhyme Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Slide the bottom back casing off, pulling down.
  2. HTC Rhyme Speaker Replacement: passo 2, imagem 1 %32 HTC Rhyme Speaker Replacement: passo 2, imagem 2 %32
    • Using the plastic tool, pry underneath the top plastic cover.
  3. HTC Rhyme Speaker Replacement: passo 3, imagem 1 %32 HTC Rhyme Speaker Replacement: passo 3, imagem 2 %32
    • Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker.
  4. HTC Rhyme Speaker Replacement, Removing the Back Plastic Motherboard Cover: passo 4, imagem 1 %32 HTC Rhyme Speaker Replacement, Removing the Back Plastic Motherboard Cover: passo 4, imagem 2 %32
    • Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard.
  5. HTC Rhyme Speaker Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the yellow ribbon by gently pulling on it.
  6. HTC Rhyme Speaker Replacement: passo 6, imagem 1 %32 HTC Rhyme Speaker Replacement: passo 6, imagem 2 %32
    • Using the plastic tweezers, gently lift the blue flaps up.
  7. HTC Rhyme Speaker Replacement: passo 7, imagem 1 %32 HTC Rhyme Speaker Replacement: passo 7, imagem 2 %32
    • Using your thumb, push the flap up on the top.
    • Using your thumb, push the flap up on the bottom of the motherboard.
  8. HTC Rhyme Speaker Replacement, Unscrewing the Motherboard: passo 8, imagem 1 %32 HTC Rhyme Speaker Replacement, Unscrewing the Motherboard: passo 8, imagem 2 %32
    • Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard.
  9. HTC Rhyme Speaker Replacement, Removing the Motherboard: passo 9, imagem 1 %32
    • Carefully remove the motherboard from the base of the phone.
  10. HTC Rhyme Speaker Replacement: passo 10, imagem 1 %32 HTC Rhyme Speaker Replacement: passo 10, imagem 2 %32 HTC Rhyme Speaker Replacement: passo 10, imagem 3 %32
    • Gently push the base of the phone from the frame.
  11. HTC Rhyme Speaker Replacement, Battery Removal: passo 11, imagem 1 %32 HTC Rhyme Speaker Replacement, Battery Removal: passo 11, imagem 2 %32
    • Using the metal spudger, remove the battery from the base.
  12. HTC Rhyme Speaker Replacement, Locating and Replacing the Speaker: passo 12, imagem 1 %32 HTC Rhyme Speaker Replacement, Locating and Replacing the Speaker: passo 12, imagem 2 %32
    • Using tweezers, lift the secondary motherboard from the base of the phone.
    • The speaker is located on the back of the board.
Conclusão
Kelsey Harris
Membro desde: 10/08/14
154 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-6, Leahy Fall 2014 Membro de USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 351
