Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
Using a Torx T4 screwdriver, remove the six screws from the six spots shown in the photo.
Use a spudger to pry the casing from the phone.
Shown here is the vibration Monitor, this is what you will be replacing.
Remove the body of the monitor from the case attaching it to the motherboard.
Make sure to remove any potential obstruction that could be blocking the weight at the end!
Carefully disconnect the cable attached at the motherboard.
Insert the replacement's cable into the same spot on the logic board! Then just set it back into the slot on the logic board and you are done!
