Introdução
Hello! This should be followed if your phone is having issues with the vibration function. Please be sure to follow the steps in the screen replacement guide up to the indicated point! Have fun fixing your tech!
O que você precisa
Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
Using a Torx T4 screwdriver, remove the six screws from the six spots shown in the photo.
Use a spudger to pry the casing from the phone.
Quase terminado!
Conclusão
