Ir para o conteúdo principal
HTC Radar 4G Touch Digitizer Replacement
O que você precisa
  1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: passo 1, imagem 1 %32 HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: passo 1, imagem 2 %32
    • Slide the lower plastic panel off of the phone.
    • Remove the four screws from the white plastic cover of the phone using the T5 Torx screwdriver.
    • Remove the two black screws from the silver frame.
  2. HTC Radar 4G Touch Digitizer Replacement: passo 2, imagem 1 %32
    • Remove the back cover by pressing on the back of the motherboard lightly and pulling the screen out carefully.
  3. HTC Radar 4G Touch Digitizer Replacement: passo 3, imagem 1 %32
    • Remove the battery from the phone using a fingernail or an opening pick.
  4. HTC Radar 4G Touch Digitizer Replacement: passo 4, imagem 1 %32
    • Remove the three screws using a screwdriver.
    • Remove the plastic frame.
  5. HTC Radar 4G Touch Digitizer Replacement: passo 5, imagem 1 %32 HTC Radar 4G Touch Digitizer Replacement: passo 5, imagem 2 %32 HTC Radar 4G Touch Digitizer Replacement: passo 5, imagem 3 %32
    • Remove the upper board and motherboard from the phone using an opening tool.
    • The regular black nylon spudger should be used whenever possible, especially around motherboards.
  6. HTC Radar 4G Touch Digitizer Replacement: passo 6, imagem 1 %32 HTC Radar 4G Touch Digitizer Replacement: passo 6, imagem 2 %32
    • Use your hands to remove the touch digitizer.
Conclusão
Kevin Guerra
Membro desde: 10/10/16
101 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 12-5, Bennett Fall 2016 Membro de Texas Tech, Team 12-5, Bennett Fall 2016
TTU-BENNETT-F16S12G5
4 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 31
Ao todo: 501
