Ir para o conteúdo principal
HTC Ozone Keyboard Replacement
O que você precisa
  1. HTC Ozone Keyboard Replacement, Rear Battery Cover: passo 1, imagem 1 %32
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Keyboard Replacement: passo 2, imagem 1 %32 HTC Ozone Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Keyboard Replacement, Battery: passo 3, imagem 1 %32 HTC Ozone Keyboard Replacement, Battery: passo 3, imagem 2 %32 HTC Ozone Keyboard Replacement, Battery: passo 3, imagem 3 %32
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Keyboard Replacement, Frame: passo 4, imagem 1 %32 HTC Ozone Keyboard Replacement, Frame: passo 4, imagem 2 %32
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Keyboard Replacement: passo 5, imagem 1 %32 HTC Ozone Keyboard Replacement: passo 5, imagem 2 %32 HTC Ozone Keyboard Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Keyboard Replacement, Motherboard: passo 6, imagem 1 %32 HTC Ozone Keyboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Keyboard Replacement: passo 7, imagem 1 %32 HTC Ozone Keyboard Replacement: passo 7, imagem 2 %32
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Keyboard Replacement: passo 8, imagem 1 %32 HTC Ozone Keyboard Replacement: passo 8, imagem 2 %32 HTC Ozone Keyboard Replacement: passo 8, imagem 3 %32
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone Keyboard Replacement, LCD Display: passo 9, imagem 1 %32 HTC Ozone Keyboard Replacement, LCD Display: passo 9, imagem 2 %32
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone Keyboard Replacement: passo 10, imagem 1 %32
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone Keyboard Replacement: passo 11, imagem 1 %32 HTC Ozone Keyboard Replacement: passo 11, imagem 2 %32
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone Keyboard Replacement: passo 12, imagem 1 %32
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone Keyboard Replacement: passo 13, imagem 1 %32
    • Lift the Motherboard away from the LCD display.
  14. HTC Ozone Keyboard Replacement, Keyboard: passo 14, imagem 1 %32 HTC Ozone Keyboard Replacement, Keyboard: passo 14, imagem 2 %32
    • Lift off main keyboard from front plastic case using plastic opening tool.
  15. HTC Ozone Keyboard Replacement: passo 15, imagem 1 %32 HTC Ozone Keyboard Replacement: passo 15, imagem 2 %32
    • Remove four Phillips #00 screws securing function keys.
  16. HTC Ozone Keyboard Replacement: passo 16, imagem 1 %32 HTC Ozone Keyboard Replacement: passo 16, imagem 2 %32
    • Pop keys out by pushing keys from back of the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Marco Jokada
Membro desde: 04/28/11
247 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 51
Ao todo: 2,021
