Ir para o conteúdo principal
HTC One X SIM Card Tray Replacement
O que você precisa
  1. HTC One X SIM Card Tray Replacement, SIM Card Tray: passo 1, imagem 1 %32
    • Insert a safety pin or other small object in the small opening next to the SIM card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
  2. HTC One X SIM Card Tray Replacement, Repair SIM card tray: passo 2, imagem 1 %32
    • Cut a piece of tape/ paper approximately the size of your Sim Card and secure it to the back side of the Sim. Be sure to trim any excess.
    • It's important that you place the tape on the back side of the Sim Card as it will block the communication with the device if placed on the front side
    • Slowly slide the Sim Card tray back into the device. It should be a smooth transition, don't force the tray in.
    • If the tray is still loose you can keep adding tape/paper until it's no longer loose.
Conclusão
5 outras pessoas executaram este guia.
Blain Abebe
Membro desde: 09/22/14
766 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 4-3, Brown Fall 2014 Membro de USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 6,898
