Ir para o conteúdo principal
HTC One X Plus Top Speaker Replacement
O que você precisa
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: passo 1, imagem 1 %32
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: passo 2, imagem 1 %32 HTC One X Plus Top Speaker Replacement: passo 2, imagem 2 %32 HTC One X Plus Top Speaker Replacement: passo 2, imagem 3 %32
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: passo 3, imagem 1 %32 HTC One X Plus Top Speaker Replacement: passo 3, imagem 2 %32 HTC One X Plus Top Speaker Replacement: passo 3, imagem 3 %32
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: passo 4, imagem 1 %32 HTC One X Plus Top Speaker Replacement: passo 4, imagem 2 %32 HTC One X Plus Top Speaker Replacement: passo 4, imagem 3 %32
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: passo 5, imagem 1 %32 HTC One X Plus Top Speaker Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: passo 6, imagem 1 %32 HTC One X Plus Top Speaker Replacement: passo 6, imagem 2 %32 HTC One X Plus Top Speaker Replacement: passo 6, imagem 3 %32
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: passo 7, imagem 1 %32 HTC One X Plus Top Speaker Replacement: passo 7, imagem 2 %32
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
Jason Melo
Membro desde: 08/26/15
483 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 3-3, Eyestone Fall 2015 Membro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 430
