Ir para o conteúdo principal
HTC One X Plus Motherboard Replacement
O que você precisa
  1. HTC One X Plus Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
  2. HTC One X Plus Motherboard Replacement: passo 2, imagem 1 %32 HTC One X Plus Motherboard Replacement: passo 2, imagem 2 %32 HTC One X Plus Motherboard Replacement: passo 2, imagem 3 %32
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Motherboard Replacement: passo 3, imagem 1 %32 HTC One X Plus Motherboard Replacement: passo 3, imagem 2 %32 HTC One X Plus Motherboard Replacement: passo 3, imagem 3 %32
    • Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Motherboard Replacement: passo 4, imagem 1 %32 HTC One X Plus Motherboard Replacement: passo 4, imagem 2 %32 HTC One X Plus Motherboard Replacement: passo 4, imagem 3 %32
    • Use the J000 Philips screw driver head to remove the screws as pictured.
    • There are two 3.4mm screws to be removed.
    • Remove the PCB board and the antenna.
  5. HTC One X Plus Motherboard Replacement: passo 5, imagem 1 %32 HTC One X Plus Motherboard Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, disconnect the power button flex cable.
    • Then disconnect the touch screen flex cable.
  6. HTC One X Plus Motherboard Replacement: passo 6, imagem 1 %32 HTC One X Plus Motherboard Replacement: passo 6, imagem 2 %32 HTC One X Plus Motherboard Replacement: passo 6, imagem 3 %32
    • Disconnect the battery from the logic board.
    • Look for a white six pin connector.
    • Remove the battery by pulling upwards.
  7. HTC One X Plus Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the remaining two flex cables following the same procedure from Step 5.
    • Once these two flex cables have been disconnected, you may now remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Jason Melo
Membro desde: 08/26/15
483 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 3-3, Eyestone Fall 2015 Membro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,245
