Ir para o conteúdo principal
HTC One X Plus Battery Replacement
O que você precisa
  1. HTC One X Plus Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Battery Replacement: passo 2, imagem 1 %32 HTC One X Plus Battery Replacement: passo 2, imagem 2 %32 HTC One X Plus Battery Replacement: passo 2, imagem 3 %32
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Battery Replacement: passo 3, imagem 1 %32 HTC One X Plus Battery Replacement: passo 3, imagem 2 %32 HTC One X Plus Battery Replacement: passo 3, imagem 3 %32
    • Remove the five 2.4mm screws using a Phillips head screw driver and then remove the plastic cover.
  4. HTC One X Plus Battery Replacement: passo 4, imagem 1 %32 HTC One X Plus Battery Replacement: passo 4, imagem 2 %32 HTC One X Plus Battery Replacement: passo 4, imagem 3 %32
    • Remove the two 3.4 mm JIS #000 screws from the PCB board.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Battery Replacement: passo 5, imagem 1 %32 HTC One X Plus Battery Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
  6. HTC One X Plus Battery Replacement: passo 6, imagem 1 %32 HTC One X Plus Battery Replacement: passo 6, imagem 2 %32 HTC One X Plus Battery Replacement: passo 6, imagem 3 %32
    • Disconnect the battery from the logic board by detaching the six pin connector.
    • Remove the battery by pulling upwards.
Conclusão
3 outras pessoas executaram este guia.
Vitterio Crisp
Membro desde: 08/26/15
119 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 3-3, Eyestone Fall 2015 Membro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 4,068
