Ir para o conteúdo principal
HTC One X LCD Display & Touch Screen Glass Digitizer Replacement
O que você precisa
Vídeo de Apresentação
  1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: passo 1, imagem 1 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: passo 1, imagem 2 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: passo 1, imagem 3 %32
    • Switch-off the phone (if you can).
    • Remove the SIM tray.
    • The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
  2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 2, imagem 1 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 2, imagem 2 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 2, imagem 3 %32
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 3, imagem 1 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 3, imagem 2 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 3, imagem 3 %32
    • The mother board is held by 6x Philips screws.
  4. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 4, imagem 1 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 4, imagem 2 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 4, imagem 3 %32
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Use a plastic tool to unstick the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  5. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 5, imagem 1 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 5, imagem 2 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 5, imagem 3 %32
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery from the mainboard.
  6. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 6, imagem 1 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 6, imagem 2 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 6, imagem 3 %32
    • At the beginning you can use a cutter to make a room for the plastic tool.
    • During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
  7. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 7, imagem 1 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 7, imagem 2 %32 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 7, imagem 3 %32
    • The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original.
    • Gently assemble the screen to the frame.
  8. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: passo 8, imagem 1 %32
Conclusão
14 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.278 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
Um comentário
i need touch panel do you have available
osama siddique - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 38,260
