Ir para o conteúdo principal
HTC One V Vibrator Replacement
O que você precisa
  1. HTC One V Vibrator Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 1 %32 HTC One V Vibrator Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 2 %32 HTC One V Vibrator Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 3 %32
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. HTC One V Vibrator Replacement: passo 2, imagem 1 %32
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. HTC One V Vibrator Replacement: passo 3, imagem 1 %32 HTC One V Vibrator Replacement: passo 3, imagem 2 %32
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. HTC One V Vibrator Replacement: passo 4, imagem 1 %32 HTC One V Vibrator Replacement: passo 4, imagem 2 %32 HTC One V Vibrator Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. HTC One V Vibrator Replacement, Disassembling HTC One V Back Case: passo 5, imagem 1 %32 HTC One V Vibrator Replacement, Disassembling HTC One V Back Case: passo 5, imagem 2 %32 HTC One V Vibrator Replacement, Disassembling HTC One V Back Case: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
  6. HTC One V Vibrator Replacement: passo 6, imagem 1 %32 HTC One V Vibrator Replacement: passo 6, imagem 2 %32 HTC One V Vibrator Replacement: passo 6, imagem 3 %32
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
  7. HTC One V Vibrator Replacement: passo 7, imagem 1 %32 HTC One V Vibrator Replacement: passo 7, imagem 2 %32 HTC One V Vibrator Replacement: passo 7, imagem 3 %32
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
  8. HTC One V Vibrator Replacement, Battery: passo 8, imagem 1 %32
    • Pry up the battery with the flat end of the spudger.
  9. HTC One V Vibrator Replacement: passo 9, imagem 1 %32 HTC One V Vibrator Replacement: passo 9, imagem 2 %32 HTC One V Vibrator Replacement: passo 9, imagem 3 %32
    • Gently lift up the battery away from the edge of its housing.
    • Use the point end of the spudger to push the connection out of its housing.
  10. HTC One V Vibrator Replacement, Camera Lens: passo 10, imagem 1 %32 HTC One V Vibrator Replacement, Camera Lens: passo 10, imagem 2 %32 HTC One V Vibrator Replacement, Camera Lens: passo 10, imagem 3 %32
    • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
  11. HTC One V Vibrator Replacement: passo 11, imagem 1 %32
    • Pry off the camera lens using a plastic opening tool.
  12. HTC One V Vibrator Replacement, Vibrator: passo 12, imagem 1 %32 HTC One V Vibrator Replacement, Vibrator: passo 12, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Pry the vibrator out of the housing with a spudger.
    • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
Conclusão
Michael Lucido
Membro desde: 01/20/15
852 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 1-3, Blackwell Winter 2015 Membro de USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Membros
Autoria de 16 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 370
