Pular para o conteúdo principal
Introdução
This guide will take you through the process of replacing the speakers for the HTC One Remix.
  1. Use the sim eject tool to remove the SIM cards on either side of the phone.
    • Use the sim eject tool to remove the SIM cards on either side of the phone.
  2. Place the warm iOpener on the top of the phone for three minutes.
  3. Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
    • Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
    • The top is glued on so it may be difficult to get off.
  4. Remove the single 3 mm screw that is on the top left side using a Torx 4 screwdriver.
    • Remove the single 3 mm screw that is on the top left side using a Torx 4 screwdriver.
  5. Use the plastic prying tool to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone. Be careful to not break the wiring that is connected from the inside to the back of the phone.
    • Use the plastic prying tool to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone.
    • Be careful to not break the wiring that is connected from the inside to the back of the phone.
  6. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  7. With tweezers, remove the small pieces of yellow tape that cover the zif connectors. Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper plate.
    • With tweezers, remove the small pieces of yellow tape that cover the zif connectors.
    • Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper plate.
  8. With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it. Use tweezers to carefully detach the eight ribbon cables from the connectors. Use tweezers to carefully detach the eight ribbon cables from the connectors.
    • With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it.
    • Use tweezers to carefully detach the eight ribbon cables from the connectors.
  9. Remove the two 1 mm screws at the bottom right of the motherboard using a Torx 4 screwdriver.
    • Remove the two 1 mm screws at the bottom right of the motherboard using a Torx 4 screwdriver.
  10. Pull off one end of each of the five colored connecting cables from the motherboard. Pull the black and red wire from the motherboard on the bottom left. Below the bottom left gold cable.
    • Pull off one end of each of the five colored connecting cables from the motherboard.
    • Pull the black and red wire from the motherboard on the bottom left.
    • Below the bottom left gold cable.
  11. Remove the four 3 mm screws on each corner of the motherboard using a Torx 4 screwdriver.
    • Remove the four 3 mm screws on each corner of the motherboard using a Torx 4 screwdriver.
    • Gently lift the motherboard out of the phone using the plastic opening tool.
    • Make sure the ribbon cables are out of the way when removing the motherboard.
  12. With a plastic opening tool, remove the black speaker at the bottom of the phone.
    • With a plastic opening tool, remove the black speaker at the bottom of the phone.
  13. Loosen the camera on the phone using a plastic opening tool.
    • Loosen the camera on the phone using a plastic opening tool.
    • Do not detach the camera from the phone itself.
  14. Remove the gold tape at the top right corner of the phone and disconnect the ribbon wire from the circuit board.
    • Remove the gold tape at the top right corner of the phone and disconnect the ribbon wire from the circuit board.
  15. Remove the four 1mm screws on the circuit board using a Phillips #00 screwdriver.
    • Remove the four 1mm screws on the circuit board using a Phillips #00 screwdriver.
    • Remove the circuit board.
  16. Using a plated screwdriver, remove the magnetic speaker from the phone itself. Using a plated screwdriver, remove the magnetic speaker from the phone itself.
    • Using a plated screwdriver, remove the magnetic speaker from the phone itself.
Conclusão
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 54
