Introdução
This guide will show you how to replace a cracked or damaged digitizer and lcd in your HTC One Mini
O que você precisa
Use a plastic opening tool next to the usb port to gently lift the bottom away from the backing.
Use a second tool to work your way around the phone undoing the clips while the first tool lifts the undone areas
Undo the 2 Phillips screws circled in red and detach the battery connector (so we don't short anything out)
Undo the 3 screws holding down the bottom of the logic board and charger port circled in green
Undo the flex cables and speaker power cable circled in blue and lift the charger port out
Gently using a plastic opening tool lift out the bottom speaker
Also the rubber spacer circled in blue
Undo the flex cables circled in orange and slowly start pulling the old screen out
Fold the screen away from the body keeping in mind not to damage the flex cables.
Add your strips of adhesive tape to the frame and put put the screen onto the body (I have highlighted the placement areas in blue)
Follow the steps in reverse for reassembly and use a couple of drops of super glue to put the front speaker cover back on
10 outras pessoas executaram este guia.
2 comentários
Where can i find a replacement screen
