Introdução
This guide will show you how to remove the case on your HTC One Mini
O que você precisa
Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
Remove the lower speaker cover.
3 outras pessoas executaram este guia.
