Ir para o conteúdo principal
HTC One Mini Motherboard Replacement
O que você precisa
  1. HTC One Mini Motherboard Replacement, iOpener Heating: passo 1, imagem 1 %32
    • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
    Pergunte ao FixBot
  2. HTC One Mini Motherboard Replacement, Remove Speaker Grills: passo 2, imagem 1 %32
    • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Remove the lower speaker cover.
    Pergunte ao FixBot
  3. HTC One Mini Motherboard Replacement, Remove Screw: passo 3, imagem 1 %32 HTC One Mini Motherboard Replacement, Remove Screw: passo 3, imagem 2 %32 HTC One Mini Motherboard Replacement, Remove Screw: passo 3, imagem 3 %32
    • Remove the screw under the speaker cover using a T6 Torx screwdriver.
    Pergunte ao FixBot
  4. HTC One Mini Motherboard Replacement: passo 4, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 4, imagem 2 %32 HTC One Mini Motherboard Replacement: passo 4, imagem 3 %32
    • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
    • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
    Pergunte ao FixBot
  5. HTC One Mini Motherboard Replacement, Separate Rear Case: passo 5, imagem 1 %32 HTC One Mini Motherboard Replacement, Separate Rear Case: passo 5, imagem 2 %32
    • Remove the rear case from the phone.
    Pergunte ao FixBot
  6. HTC One Mini Motherboard Replacement, Remove Screws: passo 6, imagem 1 %32 HTC One Mini Motherboard Replacement, Remove Screws: passo 6, imagem 2 %32 HTC One Mini Motherboard Replacement, Remove Screws: passo 6, imagem 3 %32
    • Remove the two Phillips screws securing the battery connector.
    Pergunte ao FixBot
  7. HTC One Mini Motherboard Replacement: passo 7, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 7, imagem 2 %32
    • Disconnect the battery by prying the metal cover straight up.
    Pergunte ao FixBot
  8. HTC One Mini Motherboard Replacement, Remove screws: passo 8, imagem 1 %32 HTC One Mini Motherboard Replacement, Remove screws: passo 8, imagem 2 %32 HTC One Mini Motherboard Replacement, Remove screws: passo 8, imagem 3 %32
    • Remove two Phillips screws.
    • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
    Pergunte ao FixBot
  9. HTC One Mini Motherboard Replacement, Remove Screws: passo 9, imagem 1 %32 HTC One Mini Motherboard Replacement, Remove Screws: passo 9, imagem 2 %32 HTC One Mini Motherboard Replacement, Remove Screws: passo 9, imagem 3 %32
    • Remove the two small black Phillips screws.
    Pergunte ao FixBot
  10. HTC One Mini Motherboard Replacement, Remove Screws: passo 10, imagem 1 %32 HTC One Mini Motherboard Replacement, Remove Screws: passo 10, imagem 2 %32 HTC One Mini Motherboard Replacement, Remove Screws: passo 10, imagem 3 %32
    • Remove two more Phillips screws.
    Pergunte ao FixBot
  11. HTC One Mini Motherboard Replacement, Remove protective foil.: passo 11, imagem 1 %32 HTC One Mini Motherboard Replacement, Remove protective foil.: passo 11, imagem 2 %32 HTC One Mini Motherboard Replacement, Remove protective foil.: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
    Pergunte ao FixBot
  12. HTC One Mini Motherboard Replacement: passo 12, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 12, imagem 2 %32
    • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
    • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
    Pergunte ao FixBot
  13. HTC One Mini Motherboard Replacement: passo 13, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 13, imagem 2 %32 HTC One Mini Motherboard Replacement: passo 13, imagem 3 %32
    • Peel off the silver strip with your tweezers.
    • Using your hands, detach the black strip from the board without removing it.
    Pergunte ao FixBot
  14. HTC One Mini Motherboard Replacement: passo 14, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 14, imagem 2 %32
    • Detach carefully with your tweezers the volume buttons.
    • Detach the power button with your tweezers.
    Pergunte ao FixBot
  15. HTC One Mini Motherboard Replacement: passo 15, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 15, imagem 2 %32 HTC One Mini Motherboard Replacement: passo 15, imagem 3 %32
    • Identify the screw behind the cable.
    • Remove the screw using a Phillips screwdriver.
    Pergunte ao FixBot
  16. HTC One Mini Motherboard Replacement: passo 16, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 16, imagem 2 %32
    • Lift the motherboard, but don't try to remove it completely yet.
    • Handle the board only by the edges.
    Pergunte ao FixBot
  17. HTC One Mini Motherboard Replacement: passo 17, imagem 1 %32 HTC One Mini Motherboard Replacement: passo 17, imagem 2 %32 HTC One Mini Motherboard Replacement: passo 17, imagem 3 %32
    • Using your tweezers, remove the black square located in the power button.
    • Remove the motherboard completely.
    Pergunte ao FixBot
Conclusão
Equipe
USF Tampa, Team 3-4, Brown Fall 2014 Membro de USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 72
Ao todo: 5,397
