Ir para o conteúdo principal
HTC One Mini 2 Back Plate Replacement
O que você precisa
  1. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: passo 1, imagem 1 %32 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: passo 1, imagem 2 %32 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: passo 1, imagem 3 %32
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
  2. HTC One Mini 2 Back Plate Replacement: passo 2, imagem 1 %32
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
  3. HTC One Mini 2 Back Plate Replacement, Front Plate: passo 3, imagem 1 %32 HTC One Mini 2 Back Plate Replacement, Front Plate: passo 3, imagem 2 %32 HTC One Mini 2 Back Plate Replacement, Front Plate: passo 3, imagem 3 %32
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
  4. HTC One Mini 2 Back Plate Replacement: passo 4, imagem 1 %32 HTC One Mini 2 Back Plate Replacement: passo 4, imagem 2 %32
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
  5. HTC One Mini 2 Back Plate Replacement: passo 5, imagem 1 %32 HTC One Mini 2 Back Plate Replacement: passo 5, imagem 2 %32
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
Conclusão
5 outras pessoas executaram este guia.
Caleb Kelsay
Membro desde: 10/14/14
590 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-48, Amido Fall 2014 Membro de Cal Poly, Team 4-48, Amido Fall 2014
CPSU-AMIDO-F14S4G48
Membros da 5
Autoria de 17 guias
Um comentário
what is the black ribbon antenna on the front
deancvijic90 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 10,364
