Ir para o conteúdo principal
HTC One Max Fingerprint Sensor Replacement
O que você precisa
  1. HTC One Max Fingerprint Sensor Replacement, Back Case: passo 1, imagem 1 %32
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    Pergunte ao FixBot
  2. HTC One Max Fingerprint Sensor Replacement: passo 2, imagem 1 %32 HTC One Max Fingerprint Sensor Replacement: passo 2, imagem 2 %32
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    Pergunte ao FixBot
  3. HTC One Max Fingerprint Sensor Replacement: passo 3, imagem 1 %32
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    Pergunte ao FixBot
  4. HTC One Max Fingerprint Sensor Replacement: passo 4, imagem 1 %32 HTC One Max Fingerprint Sensor Replacement: passo 4, imagem 2 %32
    • Use the small plastic opening tool to pry between the screen and the rear case.
    Pergunte ao FixBot
  5. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: passo 5, imagem 1 %32 HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
    Pergunte ao FixBot
Conclusão
Equipe
USF Tampa, Team 11-3, Blackwell Fall 2014 Membro de USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 58
Ao todo: 1,540
