Ir para o conteúdo principal
HTC One M9 Battery Replacement
O que você precisa
  1. HTC One M9 Battery Replacement, MicroSD Card: passo 1, imagem 1 %32 HTC One M9 Battery Replacement, MicroSD Card: passo 1, imagem 2 %32 HTC One M9 Battery Replacement, MicroSD Card: passo 1, imagem 3 %32
    • The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
    • Then press the tool or paperclip to eject the microSD card tray.
    • This may require a significant amount of force.
    • When reinserting the microSD card, ensure that it is in the correct orientation to the tray. The electrical connectors should be inserted first, with the microSD card face up.
    • It is normal for the microSD to sit imperfectly in the tray. The microSD card is easy to reposition within the tray.
  2. HTC One M9 Battery Replacement, SIM Card: passo 2, imagem 1 %32 HTC One M9 Battery Replacement, SIM Card: passo 2, imagem 2 %32 HTC One M9 Battery Replacement, SIM Card: passo 2, imagem 3 %32
    • Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
    • Press to eject the tray.
    • When reinserting the SIM card, ensure that its contacts are facing to the rear side. The tapered corner of the SIM card has to point to the outer bottom corner of the tray.
  3. HTC One M9 Battery Replacement, Rear Case: passo 3, imagem 1 %32 HTC One M9 Battery Replacement, Rear Case: passo 3, imagem 2 %32 HTC One M9 Battery Replacement, Rear Case: passo 3, imagem 3 %32
    • Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
    • Remove the two 4 mm T5 Torx screws on the top of the case.
    Be sure to remove the SIM tray and memory card tray prior to removing back case! Bent mine because that step was missing.
    cameronb - Responder
    The black plastic piece that runs across the top is very thin and is stuck on with very strong tape.
    SMcC21985 - Responder
  4. HTC One M9 Battery Replacement: passo 4, imagem 1 %32 HTC One M9 Battery Replacement: passo 4, imagem 2 %32 HTC One M9 Battery Replacement: passo 4, imagem 3 %32
    • Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly.
    • The SIM card tray and Micro SD card tray must be removed before the back cover can be removed.
    • Be careful around the power and volume buttons, as they are fairly delicate.
    • Be careful when separating the body from the display assembly, as the rear-facing camera may be stuck to the body with adhesive.
    The SIM Card and SD Card's need to be removed before the case will come apart.
    Andrew Froude - Responder
    I found a video showing someone using a 2 to 3 inch length scraper razor blade around the perimeter. On my second HTCM9 battery swap I found that leading with a square tipped X-Acto blade to begin the opening, and leaving the trailing, “already opened” gap “wedged” open with the scraper blade helped smoothly open from top (IR header) to bottom (micro USB charger port). A conventional spudger pries open too quickly and can damage and misshape the LCD’s soft bezel. The bezel surround is a much softer compound than the rear case. You can work the rear case loose by gently prying the back’s perimeter outward and occasionally inward as you progress. There are four tabs on the LCD assembly (i.e. nearby and under the pliers in step 5) on each side that protrude into the rear case. Push in toward the back, and pry outward on the back case seam around the vicinity of the tabs. This action provides clearance for the tab to loose from the case tab slot.
    Michael K - Responder
  5. HTC One M9 Battery Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a pair of tweezers to get underneath the white and blue cable connectors and gently push them upwards to disconnect them.
    Blue coax cable.. what does it do?
    Yusuf Koçaslan - Responder
  6. HTC One M9 Battery Replacement: passo 6, imagem 1 %32 HTC One M9 Battery Replacement: passo 6, imagem 2 %32
    • Remove the two 1.5 mm screws that secure the battery connector to the motherboard, using a Phillips #00 screwdriver.
    • Use a spudger to gently pry up the battery connector from its socket.
    • Do not apply pressure to the socket.
    When reassembling the phone, be sure to attach the battery connector correctly before screwing it down. It has a rectangular connector that may not seat correctly if simply screwed down.
    Jay Clark - Responder
    On my new battery the connector was not aligned precisely so the battery was not connected properly to the motherboard after screwing it in. The connector is supposed to hold on it’s own without the screws. If the connector does not hold to the motherboard without the screws, make sure that the connector is actually plugged in properly and only screw it in once it holds by itself.
    Gerrit Addiks - Responder
  7. HTC One M9 Battery Replacement: passo 7, imagem 1 %32 HTC One M9 Battery Replacement: passo 7, imagem 2 %32
    • Peel back the Kapton tape from the ZIF connectors.
    • Use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and gently slide the cables out.
    Lift up on the white portion of the connector
    Jarred Goar - Responder
  8. HTC One M9 Battery Replacement: passo 8, imagem 1 %32 HTC One M9 Battery Replacement: passo 8, imagem 2 %32 HTC One M9 Battery Replacement: passo 8, imagem 3 %32
    • Using the tweezers, carefully lift the tape covering the electrical strip, as shown in the picture.
    • Be gentle when lifting the tape as it can tear easily.
    • Use a spudger or your fingernail to lift the hinged retainer clip on the ZIF connector, and slide the cable out.
    Mine did not have the piece of tape.
  9. HTC One M9 Battery Replacement: passo 9, imagem 1 %32 HTC One M9 Battery Replacement: passo 9, imagem 2 %32 HTC One M9 Battery Replacement: passo 9, imagem 3 %32
    • Peel back the Kapton tape from the remaining three ZIF connectors, then use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and slide the cables out from each.
    • The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
    For the featured ZIF header in step 10, which originates from under the circuit board, after liberating the yellow-clear tape I used a “Plackers” dental flosser “pointed end” to carefully lift up from under the ZIF ribbon.
    the third connector what is that one for? my screen was sometimes flicker and that connector is loose from underneath the motherboard
    Sugar Bomb Gaming - Responder
  10. HTC One M9 Battery Replacement: passo 10, imagem 1 %32 HTC One M9 Battery Replacement: passo 10, imagem 2 %32 HTC One M9 Battery Replacement: passo 10, imagem 3 %32
    • Remove the dual LED flash cover with a pair of tweezers. The cover is held on with a small amount of adhesive.
    • Using a heated pair of tweezers would ease the removal of flash cover, as the heat helps weaken the adhesive .
    • Remove the cover using a minimum amount of force. The flash cover may be glued to the antenna cable(s) below.
    • Use a pair of tweezers to disconnect the two antenna cables near the camera.
    • Some models of this phone will have only one antenna cable at this location.
    • Disconnect the antenna cable near the bottom right of the phone.
  11. HTC One M9 Battery Replacement: passo 11, imagem 1 %32
    • Remove the three 4 mm T5 Torx screws that secure the motherboard.
    Great guide just one crucial warning missing! When removing the battery which is underneath the power/SD/volume cable make sure you see that and carefully remove the battery without tearing it apart! Had to learn the hard way. Fortunately it's replaceable..
    Charles Vheru - Responder
  12. HTC One M9 Battery Replacement: passo 12, imagem 1 %32 HTC One M9 Battery Replacement: passo 12, imagem 2 %32
    • Use a pair of tweezers to lift the vibrator out of its slot.
    • Avoid damaging the wires connecting the vibrator to the motherboard. Use the minimum amount of force.
    • Use an iOpener or heat gun to loosen the adhesive at the bottom of the motherboard.
    • Refer to the iOpener Instructions for further info.
    • Use a plastic opening tool, or a spudger, along the edges of the case to gently pry the motherboard out of the case.
    • Gently lift the motherboard out of the case, beginning from the top corner (near the camera).
    Mine did not have any adhesive.
  13. HTC One M9 Battery Replacement, Battery: passo 13, imagem 1 %32 HTC One M9 Battery Replacement, Battery: passo 13, imagem 2 %32
    • Using tweezers, remove the tape from the bottom of the battery.
    • Use a spudger to carefully pry the battery up from the display assembly.
    • Take care not to puncture or bend the battery.
    • Take extreme care not to tear the power and volume buttons flex cable
    Bei mir war der Akku fest verkebt, mit Klebesteifen ganz rechts und ganz links. Auch direkt unter dem Flachbandkabel zur Einschalt- und Lautstärketaste. Um den Akku auszubauen musste ich deshalb richtig Kraft aufwänden und das sehr empfindliche Kabel ist dabei gerissen. nachher habe ich gesehen, dass man die Leiste mit Einschalt- und Lautstärketaste hätte lösen können, sodass das Flachabndkabel nicht im Weg liegt.
    Ich empfehle das Lösen der Leiste VOR dem Ausbau des Akkus!
    Falls es doch schief geht: HTC One M9 Plus Laut Leise Ein Aus Taste Power Button Volume Flex Kabel kann man online erwerben.
    Janina Klose - Responder
    Na perfekt, den Tipp hätte ich ganz zu Anfang gebrauchen können. Zeigt mal wieder, dass man Anleitungen erstmal komplett lesen sollte bevor man loslegt. Hab das Kabel richtig schön abgerissen weil es nirgendwo erwähnt wird. Mal sehen wie ich weiter mache, ich tendiere gerade dazu mich dem M9 geschlagen zu geben und bei Bedarf meiner Lebensgefährtin den Akku in das M8S zu setzen, passt da ja auch…nie wieder HTC.
    Alexander Bla -
    This is where I severed the sd card cable. :(
    strelm - Responder
    Just reiterating the comments above, the battery is held on by glue strips on the left and right. I used a spludger to slowly prise the battery away from the glue on both sides, and was then able to get the battery out.
    Take extreme care near the power and volume buttons. It's better to move this out of the way while doing this.
    Bhaveet Shah - Responder
Conclusão
42 outras pessoas executaram este guia.
Michael Chan
Membro desde: 04/14/15
2.336 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-16, Maness Spring 2015 Membro de Cal Poly, Team 6-16, Maness Spring 2015
CPSU-MANESS-S15S6G16
Membros da 4
Autoria de 16 guias
19 comentários
I replaced the battery now but encountered a problem, as my phone wasn't working properly afterwards. When I switched on, it kind of reset to default and the play store app kept crashing, so I had to do a factory reset
Chris Felix - Responder
Removal went as directed, about to attempt in reverse! Wish me luck
jasonroll - Responder
Done all of this by the book but phone won't turn on charge screen lights up and charges but still won't turn on please help
cpopowski - Responder
You tore the power and volume button cable. It's a $10 replacement, no big deal. I did the same thing even after having repaired phones for years now.
Jonah -
For me works everything except touch screen :/ i dont know what i done wrong... screen works good, but can't touch it
Wojtoosh - Responder
Those snap on antenna connectors are the hardest part of this job. Really hard to line up to reconnect them. I was initially sent a bad battery, so I had to go through the whole process again with a good battery the second time, and it worked just fine. I would not want to make another attempt with those antenna connections though. I think they're easy to distort, and not made for frequent disconnects and reconnects.
Mike G. - Responder
I would say explicitly to disconnect the battery connector since i did not and saw some magic sparks frying one of the connectors of the motherboard
nightshadow1258 - Responder
Cool, success! I'm a bit OCD when it comes to my electronic repairs/assemblies. With these phones these days, we could've powered the moon landing...from a mobile pc that fits in our hands...so needless to say, it's a fight for space (no pun intended, but I laughed later) inside the cases, so batteries being a huge consumer of ever diminishing space, I'm surprised we can even get these out at all!
Brad Bolding - Responder
Tolle Anleitung haber mit ihr gestern erfolgreich denn Akku in meinem m9 wechseln können. Handy funktioniert tadellos
Bernhard Lejeune - Responder
Un bon tuto pour le changement de batterie. Je rajouterai juste une chose, les nappes ne sont pas faciles à remettre, il faut bien faire attention et faire un test d’allumage avant de refermer le téléphone !!!
Christophe MAGNANI - Responder
Successfully replaced my battery. After restarting my phone the vibration was super loud as the motor was loose in its seat. I had to stick a piece of double sided tape above the vibration motor to help sandwich it into place when the back cover was fitted. Working fine now.
Tom Burridge - Responder
We replaced the battery, all went well! Phone turns on, charging good, but when putting the SIM card back in, the phone is not recognizing it. We put the SIM card in our iPad, and it’s recognized there. So there isn’t a problem with the SIM card. Any suggestions?
seabeewyfe - Responder
Hi I tore the cable for the power button. Does the new cable need soldering?
Jeff Kar - Responder
I have just successfully replaced the battery in my HTC One M9, yay!
Beware: On my new battery the connector was not aligned precisely so the battery was not connected propery to the motherboard after screwing it in. The connector is supposed to hold on it’s own without the screws. If the connector does not hold to the motherboard without the screws, make sure that the connector is actually plugged in properly and only screw it in once it holds by itself.
I did not know this 15 minutes ago and thought i had destroyed by phone, but it was just a loose battery-connector. :-)
Thank you very much for this manual!
Completed battery replacement, but killed GPS, brightness sensor, cameras, flashlight, sd card drive, top speaker.
I checked all connections multiple times, swapped out the cable to the daughter board, tried a new daughter board. Nothing.
Difficult indeed.
Matt P - Responder
I’d like to thank iFixit for having this guide and the tools needed. This was my first repair attempt. Still not working, though. Before I pursue buying the charging port from another vendor (which I was having trouble with towards the end of its life and why I’m doing this repair now as opposed to 2 years ago), I want to confirm a few things.
Before I continue, I’d like to just note that no lights are going on, nothing is getting hot, and the portable battery (which turns off if it doesn’t detect that it’s charging anything) turns off after plugging in to phone.
One: Do we have to reapply any adhesives?
Two: Does the tape, if it’s no longer sticky, have to be purchased separately, or does that not matter?
Three: Do I need to apply any thermal paste?
If I did everything right (and the charging port is the real problem) I’d actually rate this as not difficult.
David N - Responder
I attempted this tutorial, and the phone now won’t turn on. I’ve got it plugged into the charger, and the charging LED does not light up, nor does the charging symbol appear on my screen. What could the problem be?
Oliver D - Responder
I can’t clip the battery connector back into its socket no matter how hard I try?
Tobi Oloke - Responder
Cool, thanks for this guide! I have replaced the battery with a new one and everything works just fine. There is still life in this old girl. I forgot how nice the stereo sound works when watching videos. :) Thanks!
PS. To reconnect the signal cables use a pair of tweezers to hold the connector in place and push it in with a fine screwdriver tip. You should hear and feel a distinctive “click” indicating the connector is seated properly.
Mr Matt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 59
Duração total: 54,859
