Introdução
To replace the buttons of the HTC MyTouch 4G, the Motherboard must be removed in order to get to the speakers. This guide will show how to remove the Motherboard and replace the buttons.
O que você precisa
Place the prying tool into the notch at the bottom of the case and pull up to remove.
Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
Remove the two T5x5mm Screws with the T5 Torx Screw driver.
Remove the one Phillips screw with the Phillips #00 Screwdriver.
Use the plastic opening tools to remove the back case.
There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
Using the plastic opening tools, remove the Wifi antenna.
There are three button ribbons on the phone that need to be pulled down off of the case.
With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
After removing the motherboard from the phone, the button bar is exposed and easily replaced.
Use the plastic opening tools to remove the button bar and replace it with the new one.
Uma outra pessoa concluiu este guia.
