Ir para o conteúdo principal
HTC Incredible 2 Battery Replacement
  1. HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: passo 1, imagem 1 %32 HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: passo 1, imagem 2 %32
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2 Battery Replacement: passo 2, imagem 1 %32
    • Remove the rear panel from the phone.
  3. HTC Incredible 2 Battery Replacement, Battery: passo 3, imagem 1 %32
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. HTC Incredible 2 Battery Replacement: passo 4, imagem 1 %32 HTC Incredible 2 Battery Replacement: passo 4, imagem 2 %32
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
Conclusão
Jonathan Morsch
Membro desde: 04/26/14
394 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-53, Amido Spring 2014 Membro de Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 591
