Ir para o conteúdo principal
HTC HD2 Earpiece Speaker Replacement
O que você precisa
  1. HTC HD2 Earpiece Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Earpiece Speaker Replacement: passo 2, imagem 1 %32 HTC HD2 Earpiece Speaker Replacement: passo 2, imagem 2 %32
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Earpiece Speaker Replacement, Midframe: passo 3, imagem 1 %32 HTC HD2 Earpiece Speaker Replacement, Midframe: passo 3, imagem 2 %32
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Earpiece Speaker Replacement: passo 4, imagem 1 %32 HTC HD2 Earpiece Speaker Replacement: passo 4, imagem 2 %32
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: passo 5, imagem 1 %32 HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: passo 5, imagem 2 %32 HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: passo 5, imagem 3 %32
    • Disconnect the small speaker cable from its socket on the motherboard.
    • Remove the earpiece speaker from the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Nathan Puchalski
Membro desde: 04/26/11
813 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-55, Amido Spring 2011 Membro de Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,915
