Ir para o conteúdo principal
HTC Freestyle Speaker Replacement
O que você precisa
  1. HTC Freestyle Speaker Replacement, Remove back cover: passo 1, imagem 1 %32 HTC Freestyle Speaker Replacement, Remove back cover: passo 1, imagem 2 %32
    • Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
  2. HTC Freestyle Speaker Replacement, Open plastic flap.: passo 2, imagem 1 %32 HTC Freestyle Speaker Replacement, Open plastic flap.: passo 2, imagem 2 %32
    • Fold the plastic flap open.
  3. HTC Freestyle Speaker Replacement, Reveal the battery: passo 3, imagem 1 %32 HTC Freestyle Speaker Replacement, Reveal the battery: passo 3, imagem 2 %32
    • Pull on the red tab to slide the battery out.
    • Take out the battery.
    • Replace with new battery.
  4. HTC Freestyle Speaker Replacement, Remove screws from plastic flap: passo 4, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
    • One of the five screws may be hidden beneath a "Void" sticker to the right of the serial label.
  5. HTC Freestyle Speaker Replacement, Remove plastic flap from phone: passo 5, imagem 1 %32
    • Once the screws are removed from the plastic flap, the piece should easily come out.
  6. HTC Freestyle Speaker Replacement, Remove circuiting panel: passo 6, imagem 1 %32 HTC Freestyle Speaker Replacement, Remove circuiting panel: passo 6, imagem 2 %32
    • After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons.
    • In order to remove the circuit board you must disconnect the labeled component.
  7. HTC Freestyle Speaker Replacement, Remove primary buttons: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
  8. HTC Freestyle Speaker Replacement, Separate phone housing from electrical components: passo 8, imagem 1 %32 HTC Freestyle Speaker Replacement, Separate phone housing from electrical components: passo 8, imagem 2 %32
    • Rotate your HTC Freestyle so that the main screen is facing upward and toward you.
    • Use a plastic opening tool to pry the screen and electronic internals apart from the main phone housing.
  9. HTC Freestyle Speaker Replacement, Remove screws from internal component: passo 9, imagem 1 %32 HTC Freestyle Speaker Replacement, Remove screws from internal component: passo 9, imagem 2 %32
    • Orient the component so that the battery compartment and camera are facing upwards.
    • Use the #00 Phillips screwdriver to remove the exterior screws that are holding the piece together.
    • There should be screws on both lateral sides of the phone as well as one screw in the top corner to the right of the camera
  10. HTC Freestyle Speaker Replacement, Separate the internal component into two halves: passo 10, imagem 1 %32 HTC Freestyle Speaker Replacement, Separate the internal component into two halves: passo 10, imagem 2 %32
    • Once the screws are removed, the motherboard can be separated from the other components after prying open the gold-colored clamps hidden underneath the battery compartment.
    • Rotate the phone 180 degrees and pry the second clamp that is located on the other side of the component.
    • The motherboard will then easily be removed from the rest.
  11. HTC Freestyle Speaker Replacement, Pry the screen from the front of the phone: passo 11, imagem 1 %32 HTC Freestyle Speaker Replacement, Pry the screen from the front of the phone: passo 11, imagem 2 %32
    • Once the screen and motherboard are separated, use a plastic opening tool to pry along the edges of the touchscreen. **Note, the use of a heat gun/heating element will help loosen the adhesive from behind the screen to make prying less physically straining.
    • The screen should now be fully removed.
  12. HTC Freestyle Speaker Replacement, Locate and remove speaker: passo 12, imagem 1 %32 HTC Freestyle Speaker Replacement, Locate and remove speaker: passo 12, imagem 2 %32
    Comprar
    • The speaker should still be attached to the front of the phone, so push the speaker from the front, or use metal tweezers to grab and remove through the backside of the screen.
Conclusão
Cody Haynes
Membro desde: 10/07/14
229 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-3, Leahy Fall 2014 Membro de USF Tampa, Team 8-3, Leahy Fall 2014
USFT-LEAHY-F14S8G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 285
