Ir para o conteúdo principal
HTC Flyer Battery Replacement
O que você precisa
  1. HTC Flyer Battery Replacement, Back Cover: passo 1, imagem 1 %32 HTC Flyer Battery Replacement, Back Cover: passo 1, imagem 2 %32 HTC Flyer Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer Battery Replacement: passo 2, imagem 1 %32 HTC Flyer Battery Replacement: passo 2, imagem 2 %32 HTC Flyer Battery Replacement: passo 2, imagem 3 %32
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer Battery Replacement: passo 3, imagem 1 %32 HTC Flyer Battery Replacement: passo 3, imagem 2 %32 HTC Flyer Battery Replacement: passo 3, imagem 3 %32
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer Battery Replacement: passo 4, imagem 1 %32 HTC Flyer Battery Replacement: passo 4, imagem 2 %32
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
  5. HTC Flyer Battery Replacement, Battery: passo 5, imagem 1 %32 HTC Flyer Battery Replacement, Battery: passo 5, imagem 2 %32
    • Gently unfold the black tape along the top that covers the cable attachment points.
    • Leave the tape partially attached so that it can be easily re-attached.
  6. HTC Flyer Battery Replacement: passo 6, imagem 1 %32 HTC Flyer Battery Replacement: passo 6, imagem 2 %32 HTC Flyer Battery Replacement: passo 6, imagem 3 %32
    • Use the tip of a spudger as a lever to disconnect the four cable connectors.
    • Gently pull out these cables after releasing the back piece.
  7. HTC Flyer Battery Replacement: passo 7, imagem 1 %32
    • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
  8. HTC Flyer Battery Replacement: passo 8, imagem 1 %32 HTC Flyer Battery Replacement: passo 8, imagem 2 %32 HTC Flyer Battery Replacement: passo 8, imagem 3 %32
    • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
    • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
    • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
Conclusão
4 outras pessoas executaram este guia.
Ana
Membro desde: 10/07/14
477 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-5, Leahy Fall 2014 Membro de USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 1,922
