Ir para o conteúdo principal
HTC Excalibur Battery Replacement
O que você precisa
  1. HTC Excalibur Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power the phone off. Remove the back cover of the Phone, exposing the battery.
    • Grasp the battery by the two indents on either side of it, near the bottom. Lift up, pulling the battery loose. Remove the battery completely.
    Pergunte ao FixBot
    Comentar
  2. HTC Excalibur Battery Replacement: passo 2, imagem 1 %32
    • Take the new battery and orient it correctly -- the arrow should be facing towards the camera lens, face up.
    • Insert the battery at an angle, pushing the battery in until it is aligned on the top edge. Push the rest of the battery in, snapping it into place.
    • Reattach the battery cover, and power up your phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ian Mitchell
Membro desde: 04/19/11
142 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-27, Garner Spring 2011 Membro de Cal Poly, Team 25-27, Garner Spring 2011
CPSU-GARNER-S11S25G27
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 2,392
