Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Remove the rear inner frame to gain access to the internals of the HTC Evo 4G.
O que você precisa
Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
Remove six T5 Torx screws securing the rear inner frame to the inner case.
Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
Pry up the rear inner frame along the right edge using the method described in previous steps.
Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
9 outras pessoas executaram este guia.
Um comentário
You may want people to also know they have to remove the lcd panel and the rear speaker to install them in their new rear inner panel.
