Ir para o conteúdo principal
HTC Evo 4G MicroSD card Replacement
O que você precisa
  1. HTC Evo 4G MicroSD card Replacement, Rear Panel: passo 1, imagem 1 %32
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. HTC Evo 4G MicroSD card Replacement: passo 2, imagem 1 %32
    • Lift the rear panel off of the inner rear frame.
  3. HTC Evo 4G MicroSD card Replacement, Battery: passo 3, imagem 1 %32 HTC Evo 4G MicroSD card Replacement, Battery: passo 3, imagem 2 %32
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. HTC Evo 4G MicroSD card Replacement, MicroSD card: passo 4, imagem 1 %32
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. HTC Evo 4G MicroSD card Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
Conclusão
7 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 10,461
