Ir para o conteúdo principal
HTC Evo 3D Vibrate Mechanism Replacement
O que você precisa
  1. HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: passo 1, imagem 1 %32 HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: passo 1, imagem 2 %32 HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: passo 1, imagem 3 %32
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Vibrate Mechanism Replacement: passo 2, imagem 1 %32 HTC Evo 3D Vibrate Mechanism Replacement: passo 2, imagem 2 %32
    • Remove the battery with your hands, lifting at the marked area.
  3. HTC Evo 3D Vibrate Mechanism Replacement: passo 3, imagem 1 %32
    • Remove the SD card
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Vibrate Mechanism Replacement: passo 4, imagem 1 %32 HTC Evo 3D Vibrate Mechanism Replacement: passo 4, imagem 2 %32
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be careful not rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Vibrate Mechanism Replacement: passo 5, imagem 1 %32 HTC Evo 3D Vibrate Mechanism Replacement: passo 5, imagem 2 %32 HTC Evo 3D Vibrate Mechanism Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • The vibrating mechanism is located on the motherboard, on the right.
    • The marked part is the vibrating mechanism.
    • To remove the vibrating mechanism, use the tweezers to securely hold the wire and tug on it.
    • The vibrating unit can then be disconnected from the motherboard using the tweezers, grasping the white part.
Conclusão
James Burke
Membro desde: 08/26/15
245 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-20, Meier Fall 2015 Membro de USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 246
