Introdução
In this guide we will show how to replace the screen on an HTC Evo 3D. This will include disassembling internal features of the phone in order to remove the screen.
O que você precisa
Remove the outer casing of the phone with your hands by prying and lifting at the latch.
With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
This will remove the inner case, and allow access into the inner portion of the phone.
Once the motherboard is removed, heat up the frame of the screen for 30 seconds with a heat gun or a hair dryer. This will make removal easier.
Use the plastic opening tool to pry open up one side of the screen.
Use the plastic opening tool to move around the borders and loosen the screen.
6 outras pessoas executaram este guia.
