Ir para o conteúdo principal
HTC Evo 3D Battery Replacement
  1. HTC Evo 3D Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the battery cover by carefully lifting the battery cover from the bottom of the phone.
    • Do not apply excessive pressure when removing cover, as this may damage or break the cover/clip.
  2. HTC Evo 3D Battery Replacement: passo 2, imagem 1 %32 HTC Evo 3D Battery Replacement: passo 2, imagem 2 %32
    • Remove the battery by pulling up on the lower indenture in the battery compartment.
  3. HTC Evo 3D Battery Replacement: passo 3, imagem 1 %32 HTC Evo 3D Battery Replacement: passo 3, imagem 2 %32
    • When insert the new battery, be sure to align the golden contacts on the top part of the battery compartment with the replacement battery.
Conclusão
Matthew Pope
Membro desde: 08/26/15
441 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-20, Meier Fall 2015 Membro de USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 916
