Ir para o conteúdo principal
HTC EVO 4G Speaker Replacement
O que você precisa
  1. HTC EVO 4G Speaker Replacement, Battery: passo 1, imagem 1 %32 HTC EVO 4G Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Speaker Replacement: passo 2, imagem 1 %32 HTC EVO 4G Speaker Replacement: passo 2, imagem 2 %32
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Speaker Replacement: passo 3, imagem 1 %32
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Speaker Replacement, Speaker: passo 4, imagem 1 %32
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Speaker Replacement: passo 5, imagem 1 %32 HTC EVO 4G Speaker Replacement: passo 5, imagem 2 %32 HTC EVO 4G Speaker Replacement: passo 5, imagem 3 %32
    • Using the plastic opening tool again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Speaker Replacement: passo 6, imagem 1 %32
    • use plastic pic to gently pry our the speaker
    • be sure to have your replacement unit ready
Conclusão
Sage Jurado
Membro desde: 03/13/14
1.128 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 204
