Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will walk you through the steps necessary to access the power button on your HTC Evo 4G for replacement. The four steps require no special skills. There are small parts that could get lost easily upon removal if not handled carefully.
O que você precisa
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
Uma outra pessoa concluiu este guia.
