Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will walk you through the steps necessary to access the power button on your HTC Evo 4G for replacement. The four steps require no special skills. There are small parts that could get lost easily upon removal if not handled carefully.
  1. Using the tip of your finger, lift the battery from the end closest to the camera. Remove the battery from the rear inner frame.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  2. Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
    • Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone. Lift off the inner frame from the rest of the phone to remove it. Lift off the inner frame from the rest of the phone to remove it.
    • Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone.
    • Lift off the inner frame from the rest of the phone to remove it.
  5. Carefully remove the power button located at the top of the phone Carefully remove the power button located at the top of the phone
    • Carefully remove the power button located at the top of the phone
Conclusão
Uma outra pessoa concluiu este guia.
Sage Jurado
Membro desde: 13-03-2014
912 Reputação
4 Guias de autoria
equipe
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 455
