Ir para o conteúdo principal
HTC Droid Incredible Battery Replacement
  1. HTC Droid Incredible Battery Replacement, Battery: passo 1, imagem 1 %32 HTC Droid Incredible Battery Replacement, Battery: passo 1, imagem 2 %32 HTC Droid Incredible Battery Replacement, Battery: passo 1, imagem 3 %32
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible Battery Replacement: passo 2, imagem 1 %32
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible Battery Replacement: passo 3, imagem 1 %32 HTC Droid Incredible Battery Replacement: passo 3, imagem 2 %32 HTC Droid Incredible Battery Replacement: passo 3, imagem 3 %32
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
502.990 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.141 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 1,587
