Ir para o conteúdo principal
HTC Droid Eris Battery Replacement
O que você precisa
  1. HTC Droid Eris Battery Replacement, Battery: passo 1, imagem 1 %32 HTC Droid Eris Battery Replacement, Battery: passo 1, imagem 2 %32
    • Place the device on a flat surface with the headphone outlet facing you.
    • Place the tip of one of your fingers over the highlighted spot.
    • Next, pull the back cover upwards. If this feels difficult, use the spudger.
  2. HTC Droid Eris Battery Replacement: passo 2, imagem 1 %32 HTC Droid Eris Battery Replacement: passo 2, imagem 2 %32
    • Lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place.
    • With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you.
    • If the battery is not coming out with this technique, use the plastic opening tool.
Conclusão
Elizabeth Ofori
Membro desde: 04/15/13
648 Reputação
Autoria de 6 guias
Equipe
SUNY Cortland, Team 1-2, Getto Spring 2013 Membro de SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 754
