Ir para o conteúdo principal
HTC Droid DNA Motherboard Replacement
O que você precisa
  1. HTC Droid DNA Motherboard Replacement, Remove the SIM Card Tray: passo 1, imagem 1 %32
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
    Pergunte ao FixBot
    Comentar
  2. HTC Droid DNA Motherboard Replacement, Removing the SIM Card Tray: passo 2, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Removing the SIM Card Tray: passo 2, imagem 2 %32
    • Pull out the SIM Card Tray with your fingers.
    Pergunte ao FixBot
    Comentar
  3. HTC Droid DNA Motherboard Replacement, Loosen the Phone Casing: passo 3, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Loosen the Phone Casing: passo 3, imagem 2 %32
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
    Pergunte ao FixBot
    Comentar
  4. HTC Droid DNA Motherboard Replacement, Pull the Casing Apart: passo 4, imagem 1 %32
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
    Pergunte ao FixBot
    Comentar
  5. HTC Droid DNA Motherboard Replacement, Remove the Black Tape: passo 5, imagem 1 %32
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
    Pergunte ao FixBot
    Comentar
  6. HTC Droid DNA Motherboard Replacement, Remove the Yellow Tape: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
    Pergunte ao FixBot
    Comentar
  7. HTC Droid DNA Motherboard Replacement: passo 7, imagem 1 %32
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  8. HTC Droid DNA Motherboard Replacement, Remove the Void Screw: passo 8, imagem 1 %32
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
    Pergunte ao FixBot
    Comentar
  9. HTC Droid DNA Motherboard Replacement, Remove the Screw Retaining Bracket: passo 9, imagem 1 %32
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
    Pergunte ao FixBot
    Comentar
  10. HTC Droid DNA Motherboard Replacement, Remove the Connector Screws: passo 10, imagem 1 %32
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
    Pergunte ao FixBot
    Comentar
  11. HTC Droid DNA Motherboard Replacement, Unfasten the Connectors: passo 11, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Unfasten the Connectors: passo 11, imagem 2 %32
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
    Pergunte ao FixBot
    Comentar
  12. HTC Droid DNA Motherboard Replacement, Remove the Yellow Tape: passo 12, imagem 1 %32
    • Use your tweezers to remove the two pieces of yellow tape shown.
    Pergunte ao FixBot
    Comentar
  13. HTC Droid DNA Motherboard Replacement, Flipping up the White Board: passo 13, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Flipping up the White Board: passo 13, imagem 2 %32
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
    Pergunte ao FixBot
    Comentar
  14. HTC Droid DNA Motherboard Replacement, Disconnect the Connector: passo 14, imagem 1 %32
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
    Pergunte ao FixBot
    Comentar
  15. HTC Droid DNA Motherboard Replacement, Flipping up the White Board: passo 15, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Flipping up the White Board: passo 15, imagem 2 %32
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
    Pergunte ao FixBot
    Comentar
  16. HTC Droid DNA Motherboard Replacement, Disconnect the Connector: passo 16, imagem 1 %32
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
    Pergunte ao FixBot
    Comentar
  17. HTC Droid DNA Motherboard Replacement, Flipping up the White Board: passo 17, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Flipping up the White Board: passo 17, imagem 2 %32
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
    Pergunte ao FixBot
    Comentar
  18. HTC Droid DNA Motherboard Replacement, Disconnect the Connector: passo 18, imagem 1 %32
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
    Pergunte ao FixBot
    Comentar
  19. HTC Droid DNA Motherboard Replacement, Flipping up the Black Board: passo 19, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Flipping up the Black Board: passo 19, imagem 2 %32
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
    Pergunte ao FixBot
    Comentar
  20. HTC Droid DNA Motherboard Replacement, Disconnect the Small Ribbon Connector: passo 20, imagem 1 %32
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
    Pergunte ao FixBot
    Comentar
  21. HTC Droid DNA Motherboard Replacement, Remove the Black Wire: passo 21, imagem 1 %32
    • Remove the long black wire on the left of the motherboard.
    Pergunte ao FixBot
    Comentar
  22. HTC Droid DNA Motherboard Replacement, Remove the Two Black Wires: passo 22, imagem 1 %32
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
    Pergunte ao FixBot
    Comentar
  23. HTC Droid DNA Motherboard Replacement, Remove the Screws: passo 23, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
    Pergunte ao FixBot
    Comentar
  24. HTC Droid DNA Motherboard Replacement, Remove the Motherboard: passo 24, imagem 1 %32 HTC Droid DNA Motherboard Replacement, Remove the Motherboard: passo 24, imagem 2 %32
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 4-43, Amido Fall 2014 Membro de Cal Poly, Team 4-43, Amido Fall 2014
CPSU-AMIDO-F14S4G43
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 32
Ao todo: 2,656
