Ir para o conteúdo principal
HTC Desire V Vibration Motor Replacement
O que você precisa
  1. HTC Desire V Vibration Motor Replacement, Battery: passo 1, imagem 1 %32 HTC Desire V Vibration Motor Replacement, Battery: passo 1, imagem 2 %32 HTC Desire V Vibration Motor Replacement, Battery: passo 1, imagem 3 %32
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Vibration Motor Replacement: passo 2, imagem 1 %32 HTC Desire V Vibration Motor Replacement: passo 2, imagem 2 %32 HTC Desire V Vibration Motor Replacement: passo 2, imagem 3 %32
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Vibration Motor Replacement, Midframe: passo 3, imagem 1 %32 HTC Desire V Vibration Motor Replacement, Midframe: passo 3, imagem 2 %32 HTC Desire V Vibration Motor Replacement, Midframe: passo 3, imagem 3 %32
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Vibration Motor Replacement: passo 4, imagem 1 %32 HTC Desire V Vibration Motor Replacement: passo 4, imagem 2 %32 HTC Desire V Vibration Motor Replacement: passo 4, imagem 3 %32
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Vibration Motor Replacement, Vibration Motor: passo 5, imagem 1 %32 HTC Desire V Vibration Motor Replacement, Vibration Motor: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unplug the vibration motor shown from the white plug on the motherboard.
    • You will probably need tweezers to do this.
  6. HTC Desire V Vibration Motor Replacement: passo 6, imagem 1 %32 HTC Desire V Vibration Motor Replacement: passo 6, imagem 2 %32
    • Gently remove the motor from its housing in the phone’s chassis.
    • The easiest way to do this is to lever the motor out by its rotating end using the tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
William McCusker
Membro desde: 01/29/15
1.096 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 14-3, Shirley Winter 2015 Membro de Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
Membros da 6
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 377
