Ir para o conteúdo principal
HTC Desire V Button Assembly Replacement
O que você precisa
  1. HTC Desire V Button Assembly Replacement, Battery: passo 1, imagem 1 %32 HTC Desire V Button Assembly Replacement, Battery: passo 1, imagem 2 %32 HTC Desire V Button Assembly Replacement, Battery: passo 1, imagem 3 %32
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Button Assembly Replacement: passo 2, imagem 1 %32 HTC Desire V Button Assembly Replacement: passo 2, imagem 2 %32 HTC Desire V Button Assembly Replacement: passo 2, imagem 3 %32
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Button Assembly Replacement, Midframe: passo 3, imagem 1 %32 HTC Desire V Button Assembly Replacement, Midframe: passo 3, imagem 2 %32 HTC Desire V Button Assembly Replacement, Midframe: passo 3, imagem 3 %32
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Button Assembly Replacement: passo 4, imagem 1 %32 HTC Desire V Button Assembly Replacement: passo 4, imagem 2 %32 HTC Desire V Button Assembly Replacement: passo 4, imagem 3 %32
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Button Assembly Replacement, Button Assembly: passo 5, imagem 1 %32 HTC Desire V Button Assembly Replacement, Button Assembly: passo 5, imagem 2 %32
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Button Assembly Replacement: passo 6, imagem 1 %32 HTC Desire V Button Assembly Replacement: passo 6, imagem 2 %32
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Button Assembly Replacement: passo 7, imagem 1 %32 HTC Desire V Button Assembly Replacement: passo 7, imagem 2 %32
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
Conclusão
3 outras pessoas executaram este guia.
William McCusker
Membro desde: 01/29/15
1.096 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 14-3, Shirley Winter 2015 Membro de Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
Membros da 6
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 316
