Ir para o conteúdo principal
HTC Desire HTC Desire Speaker Replacement
O que você precisa
  1. HTC Desire HTC Desire Speaker Replacement, Battery: passo 1, imagem 1 %32 HTC Desire HTC Desire Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Insert flat end of spudger into slot on the top of phone to pry off the back plate.
  2. HTC Desire HTC Desire Speaker Replacement: passo 2, imagem 1 %32 HTC Desire HTC Desire Speaker Replacement: passo 2, imagem 2 %32
    • Use flat edge of spudger to lift the bottom right corner of the battery.
    • Lift the battery out of the phone.
  3. HTC Desire HTC Desire Speaker Replacement, Vibrator: passo 3, imagem 1 %32
    • Remove the lower, two 0.5 mm screws using Torx T5 screwdriver.
  4. HTC Desire HTC Desire Speaker Replacement: passo 4, imagem 1 %32 HTC Desire HTC Desire Speaker Replacement: passo 4, imagem 2 %32
    • Use spudger to pry vibrator panel off.
  5. HTC Desire HTC Desire Speaker Replacement: passo 5, imagem 1 %32 HTC Desire HTC Desire Speaker Replacement: passo 5, imagem 2 %32
    • Use spudger to remove the vibrator.
  6. HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: passo 6, imagem 1 %32 HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: passo 6, imagem 2 %32
    • Take out the upper, two 0.5 mm Torx screws with a Torx T5 bit.
  7. HTC Desire HTC Desire Speaker Replacement: passo 7, imagem 1 %32
    • Take the middle 0.3 mm phillips screw out with the phillips J000 tip.
  8. HTC Desire HTC Desire Speaker Replacement: passo 8, imagem 1 %32 HTC Desire HTC Desire Speaker Replacement: passo 8, imagem 2 %32 HTC Desire HTC Desire Speaker Replacement: passo 8, imagem 3 %32
    • Using the spudger, pry up to remove the battery holder.
  9. HTC Desire HTC Desire Speaker Replacement: passo 9, imagem 1 %32 HTC Desire HTC Desire Speaker Replacement: passo 9, imagem 2 %32 HTC Desire HTC Desire Speaker Replacement: passo 9, imagem 3 %32
    • Using the spudger, pry the speaker out of its place.
  10. HTC Desire HTC Desire Speaker Replacement: passo 10, imagem 1 %32
    • With the springs up, place the new speaker into position.
Conclusão
4 outras pessoas executaram este guia.
Scott Olson
Membro desde: 10/22/15
274 Reputação
Autoria de 1 guia
Equipe
Montana Tech, Team 10-2, Shirk Fall 2015 Membro de Montana Tech, Team 10-2, Shirk Fall 2015
MTUM-SHIRK-F15S10G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,225
