Ir para o conteúdo principal
HTC Desire 816 Top Speaker Replacement
O que você precisa
  1. HTC Desire 816 Top Speaker Replacement, Top Speaker: passo 1, imagem 1 %32
    • Using the T5 screw driver, unscrew all of the screws that are holding down the black plastic casing.
  2. HTC Desire 816 Top Speaker Replacement: passo 2, imagem 1 %32
    • Remove the black plastics casing surrounding the motherboard with a plastic opening tool.
  3. HTC Desire 816 Top Speaker Replacement: passo 3, imagem 1 %32
    • Using the PH000 screwdriver head, unscrew the screw that is holding down the motherboard. It is located on the left side of the motherboard.
  4. HTC Desire 816 Top Speaker Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers disconnect the battery from the motherboard so that the motherboard could later be removed from the device.
  5. HTC Desire 816 Top Speaker Replacement: passo 5, imagem 1 %32
    • Once you have flipped the motherboard over, you should be able to locate the speaker at the top of the phone.
  6. HTC Desire 816 Top Speaker Replacement: passo 6, imagem 1 %32
    • Remove top speaker gently with a pair of tweezers.
    • The speaker is also connected to a flat black plastic casing which will also be removed as you lift the speaker
Conclusão
Uma outra pessoa concluiu este guia.
Edward Garcia
Membro desde: 03/25/16
527 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-3, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-3, Landers Spring 2016
UMASSD-LANDERS-S16S5G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 1,279
