Ir para o conteúdo principal
HTC Desire 816 Speaker Replacement
O que você precisa
  1. HTC Desire 816 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Speaker Replacement: passo 2, imagem 1 %32
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Speaker Replacement: passo 3, imagem 1 %32
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Speaker Replacement: passo 4, imagem 1 %32
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Speaker Replacement: passo 5, imagem 1 %32
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Speaker Replacement: passo 6, imagem 1 %32
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Speaker Replacement: passo 7, imagem 1 %32
    • Carefully lift battery backside first to disconnect the white connector.
  8. HTC Desire 816 Speaker Replacement, Bottom Speakers: passo 8, imagem 1 %32
    • Using the T5 screw driver, unscrew the following screws.
  9. HTC Desire 816 Speaker Replacement: passo 9, imagem 1 %32
    • Using the T5 screw driver remove the remaining screw at the bottom right corner of the phone.
  10. HTC Desire 816 Speaker Replacement: passo 10, imagem 1 %32
    • Lift and remove black plastic casing with a nylon spudger to access the motherboard and speaker.
  11. HTC Desire 816 Speaker Replacement: passo 11, imagem 1 %32
    • Using the PH000 unscrew the following screws that are holding down the motherboard.
  12. HTC Desire 816 Speaker Replacement: passo 12, imagem 1 %32
    • Using the PH000 screw driver, unscrew the remaining screw.
  13. HTC Desire 816 Speaker Replacement: passo 13, imagem 1 %32
    • Gently disconnect the wire located on the right side of the device from the bottom motherboard .
  14. HTC Desire 816 Speaker Replacement: passo 14, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, gently grab and lift the motherboard.
  15. HTC Desire 816 Speaker Replacement: passo 15, imagem 1 %32
    • Using a pair of tweezers, gently grab and remove the speaker.
Conclusão
5 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 5-3, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-3, Landers Spring 2016
UMASSD-LANDERS-S16S5G3
Membros da 3
Autoria de 12 guias
Um comentário
Where do you acquire new speakers? Can you tell me if the speakers are as powerful as the ones in the M8
Peter Ford - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 4,029
