Ir para o conteúdo principal
HTC Desire 816 Front Facing Camera Replacement
O que você precisa
  1. HTC Desire 816 Front Facing Camera Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Front Facing Camera Replacement: passo 2, imagem 1 %32
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Front Facing Camera Replacement: passo 3, imagem 1 %32
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Front Facing Camera Replacement: passo 4, imagem 1 %32
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Front Facing Camera Replacement: passo 5, imagem 1 %32
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Front Facing Camera Replacement: passo 6, imagem 1 %32
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Front Facing Camera Replacement: passo 7, imagem 1 %32
    • Carefully lift battery backside first to disconnect the white connector.
  8. HTC Desire 816 Front Facing Camera Replacement, Front Facing Camera: passo 8, imagem 1 %32
    • Using the T5 screwdriver, unscrew these four screws in order to remove the plastic casing.
  9. HTC Desire 816 Front Facing Camera Replacement: passo 9, imagem 1 %32
    • Remove the black plastic casing with a plastic opening tool.
  10. HTC Desire 816 Front Facing Camera Replacement: passo 10, imagem 1 %32
    • Using the PH000 screw driver head, unscrew the one screw that is holding down the mother board. (This screw is located on the left side of the motherboard.)
  11. HTC Desire 816 Front Facing Camera Replacement: passo 11, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, gently disconnect the battery wire from the motherboard.
  12. HTC Desire 816 Front Facing Camera Replacement: passo 12, imagem 1 %32
    • Lift the motherboard and peel it back.
    • Do not disconnect the motherboard from the device.
  13. HTC Desire 816 Front Facing Camera Replacement: passo 13, imagem 1 %32
    • Locate the camera and its connector.
  14. HTC Desire 816 Front Facing Camera Replacement: passo 14, imagem 1 %32
    • Using a pair of tweezers, lift the white part of the connector and disconnect the camera from the motherboard.
  15. HTC Desire 816 Front Facing Camera Replacement: passo 15, imagem 1 %32
    • Use a pair of tweezers to slide the camera out and remove the camera from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 1,431
