Ir para o conteúdo principal
HTC Desire 816 Battery Replacement
O que você precisa
  1. HTC Desire 816 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Battery Replacement: passo 2, imagem 1 %32
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Battery Replacement: passo 3, imagem 1 %32
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Battery Replacement: passo 4, imagem 1 %32
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Battery Replacement: passo 5, imagem 1 %32
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Battery Replacement: passo 6, imagem 1 %32
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Battery Replacement: passo 7, imagem 1 %32
    • Carefully lift battery backside first to disconnect the white connector.
Conclusão
12 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 5-3, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-3, Landers Spring 2016
UMASSD-LANDERS-S16S5G3
Membros da 3
Autoria de 12 guias
Um comentário
Very clear and helpful guide, thank you. I wonder though, is it necessary to remove tape residue from case before re-affixing, and if so how?
doorite2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 14,347
