Ir para o conteúdo principal
HTC Desire 700 Dual Sim Front Facing Camera Replacement
O que você precisa
  1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Battery: passo 2, imagem 1 %32
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Remove 8 Torx Screws: passo 3, imagem 1 %32
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Prying Off Rear Panel: passo 4, imagem 1 %32
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Disconnect Vibrator Wire: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. HTC Desire 700 Dual Sim Front Facing Camera Replacement: passo 7, imagem 1 %32
    • Remove volume control button ribbon with tweezers.
  8. HTC Desire 700 Dual Sim Front Facing Camera Replacement: passo 8, imagem 1 %32
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. HTC Desire 700 Dual Sim Front Facing Camera Replacement: passo 9, imagem 1 %32
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  10. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Camera: passo 10, imagem 1 %32
    • Remove the camera using the plastic opening tool as shown.
Conclusão
Steven Pate
Membro desde: 09/23/14
196 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 9-3, Blackwell Fall 2014 Membro de USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 21
Últimos 30 dias: 53
Ao todo: 1,011
