Ir para o conteúdo principal
HTC Desire 700 Dual Sim Bottom Speaker Replacement
O que você precisa
  1. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Removing Battery: passo 2, imagem 1 %32
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Remove 8 Torx Screws: passo 3, imagem 1 %32
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Prying Off Rear Panel: passo 4, imagem 1 %32
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Printed Circuit Board (PCB): passo 5, imagem 1 %32
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Bottom Speaker Replacement: passo 6, imagem 1 %32
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
  7. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Bottom Speaker: passo 7, imagem 1 %32
    • Using the spudger, pry the speaker away from the screen.
Conclusão
3 outras pessoas executaram este guia.
Steven Pate
Membro desde: 09/23/14
191 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 9-3, Blackwell Fall 2014 Membro de USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
Membros da 4
Autoria de 14 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 869
