Ir para o conteúdo principal
HTC Desire 626s Camera Lens Replacement
O que você precisa
  1. HTC Desire 626s Camera Lens Replacement, Backplate: passo 1, imagem 1 %32 HTC Desire 626s Camera Lens Replacement, Backplate: passo 1, imagem 2 %32 HTC Desire 626s Camera Lens Replacement, Backplate: passo 1, imagem 3 %32
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Camera Lens Replacement: passo 2, imagem 1 %32 HTC Desire 626s Camera Lens Replacement: passo 2, imagem 2 %32
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Camera Lens Replacement: passo 3, imagem 1 %32 HTC Desire 626s Camera Lens Replacement: passo 3, imagem 2 %32
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
  4. HTC Desire 626s Camera Lens Replacement, Camera Lens: passo 4, imagem 1 %32 HTC Desire 626s Camera Lens Replacement, Camera Lens: passo 4, imagem 2 %32 HTC Desire 626s Camera Lens Replacement, Camera Lens: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the outer colored cover of the lens.
    • Just work one end of the tweezers under the edge of the cover and gently pry it off.
  5. HTC Desire 626s Camera Lens Replacement: passo 5, imagem 1 %32
    • Use one end of the tweezers to slip underneath one of the edges of the lens.
    • If the lens is already cracked you don't need to worry about being gentle with it, because the intention is to replace it.
  6. HTC Desire 626s Camera Lens Replacement: passo 6, imagem 1 %32
    • There is adhesive holding the lens in place. Try not to scrape this up too bad because it will be used to hold the replacement lens in place.
    • Congrats you're done!
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 47
Ao todo: 396
